EdgeAuto.AllocMemFail
Description
Memory for the displayed object could not be allocated which may be due to the system running low on memory. This will result in incorrect operations.
Remedy
Check the scalability limit in the user documentation and compare it with the current configuration using 'show configuration detail' command. Once sufficient system memory is reclaimed, it is recommended that edgeAuto process be restarted using 'restart process edgeauto' command for internal state to be fully rebuilt.
Severity
Error
Message Text
Memory allocation failed when trying to allocate a %obj% structure of size %size%.
Message Parameters
Name Type
obj String
size uInt32
